Programmable Devices
21608 Discussions
SignalTap issue with lpm_mult dataa bits
I am using the SignalTap to read values off of my design. When I probe the inputs to the lpm_mult, dataa and datab, I come across wrong values.
My inputs are both 16-bits wide. However, in the SignalTap, it shows that my inputs are 20-bits wide. The following is the signal for data in SignalTap:
lpm_multt:inst|lpm_mult:lpm_mult_component|multcore:mult_core|mpar_add:padder|lpm_add_sub:adder[0]|add_sub_t5i:auto_generated|dataa[0..19]
My Modelsim-Altera simulation results do not match the SignalTap results.
Can you please help me in finding out the issue here?
Thank you.
Btw, I am using the Stratix IV board. So I hope it supports the lpm_mult megafunction.
can you post the lpm_mult .v/.vhd variation?
Here is the .vhd for the lpm_mult megafunction I am using:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.all;
ENTITY multlpm IS
PORT
clock : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END multlpm ;
ARCHITECTURE SYN OF multlpm IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0);
SIGNAL sub_wire1_bv : BIT_VECTOR (15 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC_VECTOR (15 DOWNTO 0);
COMPONENT lpm_mult
GENERIC (
lpm_hint : STRING;
lpm_pipeline : NATURAL;
lpm_representation : STRING;
lpm_type : STRING;
lpm_widtha : NATURAL;
lpm_widthb : NATURAL;
lpm_widthp : NATURAL
PORT (
datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
END COMPONENT;
BEGIN
sub_wire1_bv(15 DOWNTO 0) <= "0000000001100100";
sub_wire1 <= To_stdlogicvector(sub_wire1_bv);
result <= sub_wire0(31 DOWNTO 0);
lpm_mult_component : lpm_mult
GENERIC MAP (
lpm_hint => "INPUT_B_IS_CONSTANT=YES,MAXIMIZE_SPEED=5",
lpm_pipeline => 1,
lpm_representation => "SIGNED",
lpm_type => "LPM_MULT",
lpm_widtha => 16,
lpm_widthb => 16,
lpm_widthp => 32
PORT MAP (
clock => clock,
dataa => dataa,
datab => sub_wire1,
result => sub_wire0
END SYN;
The shown Megafunction won't expose dataa[19..0].
I guess I was reading the wrong nodes in SignalTap. I found the correct input nodes that only show 16 bits.
Thank you all for your help.
