21611 Discussions
Simulating a VHDL array
Modelsim-Altera returns an error when I try to drive the 'x' inputs in the code below:
"Error: (vsim-3455) Can force arrays only if they are one-dimensional arrays of character enums."
Here is the listing:
library ieee;
use ieee.std_logic_1164.all;
package pkg_array is
type row is array(7 downto 0) of std_logic;
type vec_array is array(integer range <>) of row;
end pkg_array;
library ieee;
use work.pkg_array.all;
entity gen_mux is
generic (n: integer := 2); -- Set the number of 8 bit inputs
port(
x: in vec_array(0 to (2**n - 1));
sel: in integer range 0 to (2**n - 1);
y: out row);
end gen_mux;
architecture description of gen_mux is
begin
y <= x(sel);
end description;
Is there a better way to do this? Or is there a way to write this so Modelsim will allow the x arrays to be driven?
Thanks for any help,
Steve
You shouldnt really create your own arrays of std_logic. Thats what std_logic_vectors are for. You cause all sorts of problems when you dont use std_logic_vector.
But you havent posted your code where you drive X, so I cant see where the error is occuring.
Okay, thanks for the help. I changed the code to:
library ieee;
type vec_array is array(integer range <>) of std_logic_vector(7 downto 0);
end pkg_array;
library ieee;
entity gen_mux is
generic (n: integer := 2); -- Set the number of 8 bit inputs (2**n)
port(
y: out std_logic_vector(7 downto 0));
end gen_mux;
begin
y <= x(sel);
end description;
Here's the tcl command I used to drive the x inputs, with the resultant error:
force -freeze sim:/gen_mux/x {{{00000001} {00000111} {10101010} {11110000}}} 0# ** Error: (vsim-3455) Can force arrays only if they are one-dimensional arrays of character enums.
Is there a way to change this code so that Modelsim-Altera will allow me to drive the inputs?
Steve
Create a testbench rather than forcing inputs from the command line. As the error says, you can only force simple inputs.
Okay, here's my attempt at a testbench:
-- Test Bench for Gen_Mux -- 4-6-11 library ieee; use ieee.std_logic_1164.all; use work.pkg_array.all; entity test_bench is generic (n: integer := 2); end entity test_bench; architecture test of test_bench is signal x: vec_array(0 to (2**n - 1)); signal sel: integer range 0 to (2**n - 1); signal y: std_logic_vector(7 downto 0); begin dut: entity work.Gen_Mux(description) port map( x => x, sel => sel, y => y); stimulus: process is begin x(0) <= "10001001"; x(1) <= "00001111"; x(2) <= "11110000"; x(3) <= "10101010"; sel <= 2; wait for 5 ns; sel <= 0; wait; end process stimulus; end test;
The code compiles without errors in Quartus 10.1 sp1. Does it look correct? Any suggestions?
Also, I have included this file in Assignments > Settings > EDA Tool Settings > Simulation > NativeLink Settings > Compile Test Bench..., but nothing happens when I run ModelSim-Altera. Is there another setting that I am missing somewhere?
Steve
no point in compiling it in quartus it will just synthesise everything away. you need to run it in modelsim. Looks like you got the theory right - try running it.
Thank you Tricky. It works perfectly. :-)
