Simulation
My testbench couldn't generate clock wave.
The code is :
always //@ (SYS_RST, SYS_CLK)
// optional sensitivity list
// @(event1 or event2 or .... eventn)
begin
// code executes for every event on sensitivity list
// insert code here --> begin
if (SYS_RST == 1) begin
SYS_CLK = 0;
end
else begin# (SYS_CLK_PERIOD/2) SYS_CLK = ~ SYS_CLK;
end
@eachvec;
// --> end
end
Following is the snapshot of the waveform and there must be something wrong with always block. Hope someone can point it out.
https://www.alteraforum.com/forum/attachment.php?attachmentid=3816
Always block doesn't have sensitivity list, you should write something like
always @* begin <...> end The main problem with your code though is that you try to change clock signal by itself (I don't know how to better put it).
Anyway, try this:
`timescale 1ns / 1ps module tb_clk_gen (); reg SYS_RST; reg SYS_CLK; initial begin:Reset_Gen SYS_RST <= 1'b0;# 50 SYS_RST <= 1'b1; end initial begin:Clock_Gen SYS_CLK <= 1'b0; wait (~SYS_RST); forever# 10 SYS_CLK <= ~SYS_CLK; end endmodule
Hi, AndrewS6:
Thanks. But there's another bug~
code 1:
--- Quote Start ---
initial begin
SYS_CLK <= 0;
$display($time, "SYS_CLK = 0");
forever# (SYS_CLK_PERIOD/2) SYS_CLK <= ~ SYS_CLK;
$display($time, "SYS_CLK reverse");
CD_PULSE <= 0;
$display($time, "CD_PULSE = 0");
forever# (CD_PULSE_PERIOD/2) CD_PULSE <= ~ CD_PULSE;
$display($time, "CD_PULSE reverse");
end
--- Quote End ---
http://www.alteraforum.com/forum/attachment.php?attachmentid=3821&stc=1&d=1300376027
code 2:
--- Quote Start ---
initial begin
SYS_CLK <= 0;
end
initial begin
CD_PULSE <= 0;
end
--- Quote End ---
http://www.alteraforum.com/forum/attachment.php?attachmentid=3822&stc=1&d=1300376034
I just put the CD_PULSE and SYS_CLK assignment in different initial block and the result is right. I am still confused about that. Hope you can help me with this.
Hello.
In your first example Modelsim executes only first forever line, other lines are not executed (you can verify this by placing breakpoint at second forever operator). This is correct operation as forever operator should be used only once in each initial block. Your second code example demonstrates just that.
I suggest you to read more about behavioral modeling so you can use this very powerful tool more precisely. See link for example:
http://www.asic-world.com/verilog/vbehave1.html
