21611 Discussions
Single Pulse in output with pulse width ibility control
Hi everyone. I have used many ways to create single out pulse with pulse width bility. So far as I know I have to use counter to count clock pulses and make the output one and zero.
I have used state machine to write my code but always there is an unwanted pulse before my code configuration.
All suggestions are Welcomed.
the output waveform is attached.
my code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ltd_auto is
port
clk : in std_logic;
data_out: out std_logic
end ltd_auto;
Architecture behavioral of ltd_auto is
signal c : integer:= 0;
constant a : integer:= 2;
constant b : integer:= 3;
type state_type is (idle, delay, zero);
signal next_s: state_type;
begin
process (clk)
begin
if (rising_edge(clk))then
case next_s is
when idle =>
c <= c + 1;
next_s <= delay;
when delay =>
if (c = a) then
data_out <= '1';
end if;
if (c = b) then
data_out <= '0';
next_s <= zero;
else
c <= c + 1;
end if;
when zero =>
c <= 0;
end case;
end if;
end process;
end behavioral;
The initial high is while the FPGA is being configured. Once configured the output is driven low and fires a single pulse as your state machine describes.
If you want your output to be low during configuration you have to add a pull-down resistor to the FPGA's pin.
or just create a initial delay either by sensing a button being pressed or when a counter reaches a certain value after FPGA is configured .
--- Quote Start ---
--- Quote End ---
Thanks for your time josyb.
I have tried to change the pull-down resistor located in Pin planner but there wasn't any change in output. I would really appreciate if you be more specific with examples or extra information. I have heard of External pull-down resistor? any idea how it works?
--- Quote Start ---
--- Quote End ---
Hi dude, Can you be more described? I have tried to use reset before rising_edge (clk) and make my output '0' but it did not work also. And because of planned usage of fpga using buttons are not easy. I want to use it in a compact place beside other devices and it could be difficult for me to use buttons. still any idea with/without buttons are welcomed.
