21611 Discussions
i dont understand this code, need your help
i found this code on the internet, they write by verilog, but im not familiar with verilog (just know about vhdl), so few things in this code that i dont understand and i need your help
/// reset ////////////////////////////////////// //state machine start up wire reset; // reset control assign reset = ~KEY; /////////////////////////////////////////////// // state variable reg state ; //oneshot gen to sync to audio clock reg last_clk ; // output to audio DAC reg signed audio_outL, audio_outR ; // input from audio ADC wire signed audio_inL, audio_inR; /// memory for phase shifter ///////////////////////////////////////// //memory control reg we; //write enable--active high wire read_data; reg write_data; reg addr_reg; //pointers into the shift register //200 samples at 48kHz for 1/4 cycle 60 Hz noise reg ptr_in, ptr_out; //make the phase shift register ram_infer PhaseShifter(read_data, addr_reg, write_data, we, CLOCK_50); ////////////////////////////////////////////////////////////////////// /// LMS ///////////////////////////////////////////////////////////// // LMS registers // 2 weights reg signed w1, w2; // 2 inputs reg signed ref60, shifted_ref60 ; // error output (main output) wire signed error_out ; // two product terms wire signed w1_x_ref, w2_x_shifted_ref; // mult for weight times ref and weight times phase-shifted ref signed_mult w1xRef(w1_x_ref, w1, ref60); signed_mult w2xRefShifted(w2_x_shifted_ref, w2, shifted_ref60) ; //assume noisy signal is on right channel, ref on left channel assign error_out = {audio_inR, 2'h0} - (w1_x_ref + w2_x_shifted_ref); ////////////////////////////////////////////////////////////////////// /* // loopback test always @ (posedge AUD_DACLRCK) begin audio_outL <= audio_inL; audio_outR <= audio_inR; end */ //debug readouts assign LEDG = state; assign LEDR = ptr_out; //Run the state machine FAST so that it completes in one //audio cycle always @ (posedge CLOCK_27) begin if (reset) begin ptr_out <= 8'h1 ; // beginning of shift register ptr_in <= 8'h0 ; we <= 1'h0 ; state <= 4'd8 ; //turn off the state machine //last_clk <= 1'h1; end else begin case (state) 1: begin // set up read ptr_out data addr_reg <= ptr_out; we <= 1'h0; // next state state <= 4'd2; end 2: begin //get ptr_out data shifted_ref60 <= {read_data, 2'h0} ; // set up write ptr_in data addr_reg <= ptr_in; we <= 1'h1; write_data <= audio_inL ; // store current ref channel ref60 <= {audio_inL, 2'h0} ; // make some output // original signal in R channel // denoised signal in L channel // audio seems to negate signal, so invert it audio_outR <= -audio_inR ; audio_outL <= -error_out; // next state state <= 4'd3; end 3: begin // turn off memroy write we <= 1'h0; // update weights w1 <= w1 + (((ref60)? -error_out : error_out)>>>10) ; w2 <= w2 + (((shifted_ref60)? -error_out : error_out)>>>10) ; // next state state <= 4'd5; end 5: begin // phase shifter pointer control // update write pointer if (ptr_in == 8'd200) //200 ptr_in <= 8'h0; else ptr_in <= ptr_in + 8'h1 ; // update read pointer if (ptr_out == 8'd200) ptr_out <= 8'h0; else ptr_out <= ptr_out + 8'h1 ; //next state is end state state <= 4'd8; end 8: begin // wait for the audio clock and one-shot it if (AUD_DACLRCK && last_clk==1) begin state <= 4'd1 ; last_clk <= 1'h0 ; end // reset the one-shot memory else if (~AUD_DACLRCK && last_clk==0) begin last_clk <= 1'h1 ; end end default: begin // default state is end state state <= 4'd8 ; end endcase end end endmodule ////////////////////////////////////////////////// //// M4k ram for circular buffer ///////////////// ////////////////////////////////////////////////// // Synchronous RAM // modified for 16 bit access // of 200 words to tune for 1/4 cycle at 60 Hz module ram_infer (q, a, d, we, clk); output reg q; input d; input a; input we, clk; reg mem ; always @ (posedge clk) begin if (we) mem <= d; q <= mem ; end endmodule //////////////////////////////////////////////////
in this code they use circular buffer to buffer stream data from the codec (DE2), they use 2 counter for read/write but in state 5, they use both up counter and jusst use one address port for both counter, is it possible ????
shifted_ref60 <= {read_data, 2'h0} ; mean when write by VHDL ????
I haven't read the code, but shifted_ref60 <= {read_data, 2'h0} ; is the same as: shifted_ref60 <= read_data & '00'; -- e.g. concatenation
--- Quote Start ---
--- Quote End ---
thanks, it realy helpfull
