Programmable Devices
21611 Discussions
Some issue on FT2232H in Synchronous FIFO
Hello everyone!
I have some troubles with the FTDI chip.
I use it in this way: FPGA+FT2232H on custom board and PC Application on the other side. All stuff using in Synchronous FIFO mode. So from now I’m trying to send a byte command from FPGA and catch it in the windows application. And here is the problem. I didn’t saw errors or warnings it just not working. Maybe someone have the same problem as I have.
Well here is my VHDL code in the key of write operation(all ports have the same name as in the datasheet):
WRITE_STR: process (CLK, TXE, RST) begin if (RST = '0' OR RD_CONTROL <= "00") then WR_CONTROL <= '1'; data_tx <= "00000000"; elsif ((CLK'EVENT) and (CLK='1')) then if (TXE = '0' and RD_CONTROL <= "11") then WR_CONTROL <= '0'; data_tx <= "01101011"; else WR_CONTROL <= '1'; end if; end if; WR <= WR_CONTROL; ADBUS <= data_tx; end process WRITE_STR;
And it is simulating right as I see (pic 01.jpg).
PC application. I use Visual C# 2010 i'm a new one here, so.
Here is the settings after the chip is opened:
ftStatus = myFtdiDevice.SetBitMode(0x00, FTDI.FT_BIT_MODES.FT_BIT_MODE_RESET); Thread.Sleep(10); ftStatus = myFtdiDevice.SetBitMode(0xFF, FTDI.FT_BIT_MODES.FT_BIT_MODE_SYNC_FIFO); if (ftStatus != FTDI.FT_STATUS.FT_OK) return false; ftStatus = myFtdiDevice.SetLatency(0x10); ftStatus = myFtdiDevice.InTransferSize(10000); ftStatus = myFtdiDevice.SetTimeouts(0, 0); ftStatus = myFtdiDevice.SetFlowControl(FTDI.FT_FLOW_CONTROL.FT_FLOW_RTS_CTS, 0x0, 0x0); ftStatus = myFtdiDevice.Purge(FTDI.FT_PURGE.FT_PURGE_RX); Thread.Sleep(10);
I'll trying to change Flow Control to 0x11, 0x13 nothing happened. Change TheTransferSize and TimeOuts still the same.
Here writting code by clicking on button, app must read one byte:
private void button1_Click_1(object sender, EventArgs e) { FTDI.FT_STATUS ftStatus = FTDI.FT_STATUS.FT_OK; UInt32 RxBytes = 0; myFtdiDevice.GetRxBytesAvailable(ref RxBytes); if (ftStatus != FTDI.FT_STATUS.FT_OK) { textBox2.Text += "FTDI.GetRxBytesAvailable failed"; return; } Byte ByteRead = new Byte; UInt32 BytesRead = 0; myFtdiDevice.Read(ByteRead, RxBytes, ref BytesRead); if (ftStatus != FTDI.FT_STATUS.FT_OK) { textBox2.Text += "FTDI.Read failed"; return; } else { textBox2.Text += "Reading data is " + Encoding.UTF8.GetString(btRead) + " from FPGA" + Environment.NewLine; // well, for example }
In the other hand if i use terminal in the Morph-IC-II Application after the FPGA is will be programmed and USB cable already plug in you can see pic 02.jpg.
Can someone explane to me how does this happen?
Check TXE and RXF on either edge, not only on rising edge
http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_1.html
--- Quote Start ---
--- Quote End ---
Can you explain more about it?
I didn't get
Example:
if (TXE = '0') ...
end if
shoud became
if (TXE = '0') ...
read the article..
