Programmable Devices
Sopc Help
hi again,
I'm using a SDRAM controller in SOPC. but things are not working right.
Failing paths, buffer of templates are getting full , ...
I'm using master write and master read MM-templates from the site.
I connected 3 read's and 5 writes to the SDRAM Controller. What else do i need to do?
Can anyone plz help me with a good tutorial or a easy reference design ?
Edit: For any help i added a pic of the sopc
where are your failing paths? Adding the pipelines should already help, but in some cases it can be the design inside your component that can be the problem.
Do you have the same problem with less masters in your SOPC design?
I'll test that.
But I also have a question: Some of my write masters get a buffer full. Fifo dept is 258 and there should be enough of time to write them to the SDRAM. If i assing a GO to 2 components at the same time the arbiter can handle that ... right or not?
I think you should use some signaltap probes to see what is happening and why your masters are frozen for so long.
One possible explanation could be that you have two masters trying to access different portions of memory at the same time, and the arbitrator is letting each one access one word at a time. In that case you loose all the latency cycles from the DRAM on each access.
The master interface has some features to speed up the access, such as bursts and/or pipelined transfers with arbitrator lock. You should look into those, to let your masters access several words in a row and avoid most of the lost latency cycles.
Yes, i have 2 images to be stored at the same time.
(2 camera's -> 1 memory).
The arbiter integer are standard 1 (as in the picture).
And i enabled a burst of 32 while the template FIFO is 256.
Is a burst of 32 enough ?
And what does a burst of 32 means? That the master has 32 clk cycles acces to the slave or that 32 data transfer occur to the slave?
Like u said, the slave needs some cycle to set the adress.
Another Question:
If u use the write - MM Master like follows:
(FIFO is filled by camera at 48MHz : 1 byte every clk)
(SDRAM works on clk of 144MHz)
U send : GO, Adress = 0x000000000 , Number of Bytes = 640 decimal
What will happen?
I can think of some things.
- FIFO will run empty and the component will have no data to transmit.
But will the write controller freeze?
Redesigned the SOPC for 1 camera -> 1 Write MM-Template
Spec of MM Template :
- FIFO = 256
- Burst Enabled and 8
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Setup paths within the SOPC with slack of -1.953
Lots of them.
--- Quote Start ---
Lots of them.
--- Quote End ---
Either you are using a too high clk frequency
or you have a bad create_clock command in the TimeQuest sdc file.
Some suggestions:
- If the SDRAM controller you are using does not support burst then don't enable bursting in the masters.
- Increase the arbitration share of each master to allow multiple back to back transfers from each master to access the SDRAM
- Increase the data width of the master to match your memory controller width
--- Quote Start ---
--- Quote End ---
Fmax is about 132MHz but that is when i remove all the others VHDL and only generate a Sopc with one Write master and one SDRAM controller.
The second option could be a problem. I don't have much experience with
SDC file or asserting constraints. I followed TimeQuest User Guide by Ryan Scoville. do i need a diffrent ip.sdc for the sopc? Here is my SDC-File for main design:
# **************************************************************# Time Information# ************************************************************** set_time_format -unit ns -decimal_places 3 # **************************************************************# Create Clock# ************************************************************** create_clock -name {FPGA_CLK1} -period 20.833 -waveform { 0.000 10.416 } create_clock -name {FPGA_CLK2} -period 20.833 -waveform { 0.000 10.416 } create_clock -name {PIX_CLK} -period 20.833 -waveform { 0.000 10.416 } # **************************************************************# Create Generated Clock# ************************************************************** derive_pll_clocks # **************************************************************# Set Clock Latency# ************************************************************** # **************************************************************# Set Clock Uncertainty# ************************************************************** derive_clock_uncertainty
FPGA_CLK_1 and _2 are 48MHz input clk's that go straight to a PLL each. They generate a freq of 48MHz and 144MHz.
The generated CLK 144MHz i use for the SOPC gives failing paths (setup)
--- Quote Start ---
Some suggestions:
--- Quote End ---
It does. It supports a burst of 1,2,4,8. I set every burst on 8.
--- Quote Start ---
--- Quote End ---
I'll try them, but i was trying to avoid the last suggestion because then i need to make the code a little more complex.
If i increase arbitration shares, that will have no affect on the slack.
or am i wrong?
Aditional info:
FPGA : Cyclone III EP3C10F256C8N
SDRAM : IS42S16400B
If more info is required plz ask.
Thx for the reply's.
Did some tests,
With 1 write master MM to SDRAM controller fmax 132MHz
I Added one -> 2 Write masters to SDRAM controller fmax 115MHz
--- Quote Start ---
--- Quote End ---
Sopc builder should have generated automatically a .sdc file for your system.
You must include it in your Quartus project.
Also make sure your checked the "Timing driven synthesis" in Analysis&Synthesis settings and follow the other guidelines reported by timing optimization advisor.
If all this fails maybe the 144MHz frequency is really too high for your device.
Final note: probably this is not your current problem, but usually you must drive the sdram clock pin with a phase lead relative to clock used by sopc system.
--- Quote Start ---
--- Quote End ---
You have to enable the settings for that? Cauze i can't find it in the main
directory.
--- Quote Start ---
--- Quote End ---
I did.
--- Quote Start ---
--- Quote End ---
Probably you need to apply that in the sdc aswell. How?
--- Quote Start ---
You have to enable the settings for that? Cauze i can't find it in the main directory.
--- Quote End ---
AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use.
Did you select TimeQuest as time analyzer?
Regarding the sdram clock phase, I remember it must be calculated somehow like this (although I'm not completely sure):
- pre-compile the project with 0 phase shift
- search the PLL offset in the timing analysis report
- search the sdram clock combinatorial delay from pll output to clock pin
- the sdram clock phase lead must be set that the sum of pll offset and combinatorial delay is a bit longer than the sdram setup time
- recompile the Quartus project
I use the same SDRAM as yours and EP3C40: with Fclk=100MHz I set dram clk phase = -27degrees = -0.75ns. As a rule of thumb you can also try -0.75ns which for your 148MHz would mean a phase lead of 40deg.
--- Quote Start ---
--- Quote End ---
I only see the SDC wich i made. I don't have one generated by SOPC builder. I use version 8.0.
I'll try shifting the SDRAM CLK but I probably need to reduce the speed of
the avalon bus with all those components on it. I was running it at 144MHz.
