21597 Discussions
Strange, counter forgets to count
Why is that sometimes, a register forgets to increment? Any causes for this? (at the attached picture, it the 'addr' should count up, but it didn't). Does a 100Mhz clock have something to do with it? Its strange
https://www.alteraforum.com/forum/attachment.php?attachmentid=8716
Because some conditions occured that meant it didnt count?
Or is your sample clock different from the clock that clocks addr?
--- Quote Start ---
--- Quote End ---
I double check the signal tap data, and the condition is there.. its just that the 'addr' forgot to change.. :(
initial begin address <= 0; chipselect <= 1'b1; byteenable <= 2'b00; reset <= 1'b1; read <= 1'b1; write <= 1'b1; state <= wzero; writedata <= 0; end parameter rzero=4'b0000, rone=4'b0001, rtwo=4'b0010, rthree=4'b0011, rfour=4'b0100, rfive=4'b0101; parameter wzero=4'b1000, wone=4'b1001, wtwo=4'b1010, wthree=4'b1011, wfour=4'b1100, wfive=4'b1101, woneone=4'b1110; always @(posedge ramclk) begin case (state) wzero: begin address <= address + 0; if(address == 999999) lastread <= writedata; if(address == 1000000) state <= rzero; else if(pclk) begin state <= wone; write <= 1; address <= address + 1'b1; writedata <= writedata + 1; end else state <= wzero; end wone: begin address <= address + 0; state <= wtwo; write <= 0; end wtwo: begin address <= address + 0; if(pclk) begin state <= wthree; write <= 1; end if(!pclk) begin state <= wzero; write <= 1; end end wthree: begin address <= address + 0; if(!pclk) begin state <= wzero; end else state <= wzero; end rzero: begin read <= 0; address <= 999999; state <= rone; end rone: begin read <= 1; state <= rone; end default: state <= wzero; endcase end
