Programmable Devices
21611 Discussions
Stratix II GX configuartion
I have a problem with the configuration of a Stratix II GX FPGA (EP2SGX130).
I am using AS-programming with EPCS64.
When I use a "standard" .pof-file the configuration procedure stops after a while (nSTATUS getting low) and starts again from the beginning. CONF_DONE does not reach high-level at all.
When I use a compressed .pof-file then all works perfectly.
Does anyone know, what the problem could be or how to debug it?
I am using a custom board for the FPGA.
On a Altera Development Board with the EP2SGX90 (and also EPCS64) it works with the compressed and the uncompressed pof-files.
Thank you for your help!
Johnny.
