I have a problem with the configuration of a Stratix II GX FPGA (EP2SGX130). I am using AS-programming with EPCS64. When I use a "standard" .pof-file the configuration procedure stops after a while (nSTATUS getting low) and starts again from the beginning. CONF_DONE does not reach high-level at all. When I use a compressed .pof-file then all works perfectly. Does anyone know, what the problem could be or how to debug it? I am using a custom board for the FPGA. On a Altera Development Board with the EP2SGX90 (and also EPCS64) it works with the compressed and the uncompressed pof-files. Thank you for your help! Johnny.Link Copied
