21615 Discussions
Stratix V Low Latency Phy
Request for comments.
I am using the Low Latency PHY in Stratix V and have an odd Critical Warning:
"Critcal Warning (178012): Coreclk source from 10G RX PCS ...+ long string"
Pertinent parameters are
Data Path Type: 10G
FPGA fabric width: 64
PCS-PMA width: 64
TX_Coreclkin and RX_Coreclkin are not enabled
RX bitslip is enabled
The design is Qsys based.
With the above, Quartus II Megawizard is happy. However, I get the above message when compiling. The compilation does run and complete in Quartus II. I do not want to convert the PCS_PMA width to 32 as I loose the RX bitslip capability. I realize the warning is recommending the use of the TX_Coreclk.
Has anyone faced this problem before? I am concerned about ignoring this.
Thanks in advance
