21602 Discussions
Stratix10 SOC 18.1 GHRD Example design : No Handoff folder/dtsi files in project directory?
Shenoy
I needed some inputs from you regarding Handoff file folder / dtsi file generation in Stratix10 case.
With Arria10 SOC designs, I was able to get a Handoff folder with XML files generated in the project directory after compilation.
I have noticed that there's no Handoff folder in the Stratix 10 SOC example design project directory. I have recompiled the design but didn't find any updated dtsi file nor any Handoff folder in the project directory.
Is there any change in steps for generating Handoff files/dtsi files in Stratix10 case? If yes, please let us know more about this and the proper way to generate the Handoff files/dtsi file.
Shenoy
FawazJ_Altera
Hello.
You should be able to see the handoff folder inside output_files folder.
thanks
