21602 Discussions
Sub -LVDS IO standard
Ajay_Khedekar
Hello ,
I have one image sensor with 20 lane Sub-LVDS output (16 lane data and 4 lane clock) with following dc characteristics
Symbol
Description
Min.
Typical
Max
Condition
VDD_IO
IO digital Supply
1.71 V
1.8 V
1.89 V
ROD
Differential output termination
79.4 Ω
100 Ω
123.5 Ω
when in differential mode
VOD
Output differential p-p voltage
0.262 V
0.54 V
VOCM
Output common mode voltage
0.9 V
i am looking for a FPGA based bridge which will convert the Sub-LVDS output to MIPI CSI-2 format. could you please suggest a FPGA (with 50-60K LUT/Logic elements) which serve this application? i have gone through few FPGA device but couldn't find any appropriate device which will receive the specified IO standard.
Ajay_Khedekar
Hello guys,
I really appreciate the your efforts.
From your suggestions, i could make the conclusion that to interface the sub LVDS i need to check the IO receiver standard specifically i need check the VICM range along with receiver swing range. Also we need to careful about choosing the DDR LVDS receiver speed as well.
FvM
if you read FPGA datasheets, you'll see that LVDS receivers of most FPGA series support Sub-LVDS level (Vicm=0.9V) with limited data rate, e.g. Cyclone 10 up to 700 MBPS. You didn't mention speed requirements but I guess that's sufficent for your application.
You also need Gigabit Transceivers to send out MIPI CSI-2. Cyclone 10 GX would be my first choice.
Ajay_Khedekar
hello  there ,
Thank you very much for your response!
accept my apologies to not providing clock details , here are the clock details,
"Synchronous serial output with sub-LVDS levels
       16 data lanes with 4 clock lanes (total of 20 lanes, 10 for even rows and 10 for odd rows)
       data transfer rate: 1100 Mbps for maximum frame rate
       DDR clock for synchronization at 550 MHz"
Could you please enlighten me little about  selecting sub LVDS receiver
dont we need to check about differential voltage swing ? as  i mentioned my data have output swing can be 0.262V to 0.54V
i went through different data available on google about subLVDS  i can see there  receiver input threshold are there could you please explain how they work ?
AqidAyman_Intel
Hereby I give you the Cyclone 10 GX Differential I/O pin datasheet for you to look into. It may fit your requirement.
Ajay_Khedekar
hello  there ,
AqidAyman_Intel
From what I understand, LVDS receiver are capable of being driven by sub-LVDS driver although the Vcm and Vid levels are reduced from typical LVDS.
However, if you refer to Intel Max 10 datasheet, there are supported sub-LVDS I/O standard listed in the table for your reference. You can refer below link:
https://www.intel.com/content/www/us/en/docs/programmable/683794/current/differential-i-o-standards-specifications.html
However
Ajay_Khedekar
Hello guys,
AqidAyman_Intel
No worries!
With that, may I know, do you need more support for this?
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous reply have been provided, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any of the answers from the community or Intel Support are helpful, please feel free to give "Kudos" or rate a 4/5 for the evaluation survey.
