21615 Discussions
Subscription Edition VS Web Edition of Quartus
For my application, i plane to work with Quartus web Edition, but i have readed that the subscribtion Edition has more option. I don't know if this option are necessary for my application (image Fusion of 2 sensors).
What are you think?
--- Quote Start ---
What are you think?
--- Quote End ---
have a look into this pdf: http://www.altera.com/literature/po/ss_quartussevswe.pdf
Kind regards
GPK
You should have no problem, assuming you're using a supported device, and dont want to use any Altera IP (like a FFT filter for the fusion).
Are you planning on writing the fusion algorithm yourself?
--- Quote Start ---
--- Quote End ---
Thanks Tricky for your Answer, i have wrote an algorithm fusion in c for a mikrocontroller, now i would try to do the same in verilog for the FPGA.
I advise you to stay away from Verilog.
Use SystemVerilog instead, it is well supported by Quartus and a LOT easier to learn than Verilog.
--- Quote Start ---
--- Quote End ---
Thank you amilcar, but i have some file in verilog that defines ports of my Board and i would use this file. That 's the reasion why i prefer to work with verilog.
