21611 Discussions
Super loop simple socket server design example
I am trying to run the design example super_loop_simple_socket_server plus using Quartus II version 10.0sp1. that is found in the following link:
http://www.alterawiki.com/wiki/superloop_simple_socket_server_plus
After successfully extracting the folder using NIOS II command shell, when writing the following command (as found in the read me file.):
create-this-app --cpu-name linux_cpu
The following error was encountered:
create-this-app --cpu-name linux_cpu command not found.
Can any one advise me on this issue.
The prompt response is highly appreciated.
Thanks & Regards.
