21602 Discussions
Synchronization of data, control and clock inputs in QuartusII
Hey everyone,
i am getting a data(4 Bit), a control(1 Bit) and a clock signal from the Cyclone V pins which are driven by extern sources.
These signals are misaligned and i want to align the control and the data signals to the extern clock signal in my FPGA design.
Are there any Altera/QuartusII provided IP-Cores available to this task? What is the best method to align them?
The deskew isn't static, so timing constrains are probably not the right solution.
I am using Cyclone V and QuartusII 2017.
Every help is very appreciated, thanks in advance.
Best regards
Add a PLL and choose one of the available clock compensation options.
