Thanks in advance for your nice instructions.
What I am doing is producing a single output pulse. It is a simple output but due my little knowledge it becomes complicated for me. What I want in output is like this [SUB]--------0-------[/SUB][SUP]-------1-------[/SUP][SUB]---------0-------[/SUB] It is simple but there are some points, As the pulse width (When pulse is "1") is important for my experiment, I have used counters to count clock cycles and make output "1" for a certain clock cycles make output "0" after certain clock cycles. But the problem is at the starting point. When I connect it to Oscilloscope the output is "1" before my commands. I have attached the Oscilloscope waveform. The waveform is always "1" before my real command. I want 0 and 1 and then 0 again without any other repetition. Please look at the code and help me for correction. As I write in the code, After 2 clock pulse (Constant a) output become "1" and after 3 clock pulse (Constant b) output become "0" again, This is for controlling the output pulse width. But the problem is about before starting. As you see in the attachment picture, output of FPGA already is "1" and then my codes acts. I am sure there are some mistake in the code, please help me to correct it.library ieee;use ieee.std_logic_1164.all;use ieee.numeric_std.all;
entity ltd_auto is
port ( clk : in std_logic;
data_out: out std_logic );
end ltd_auto;
Architecture behavioral of ltd_auto is
signal c : integer:= 0;
constant a : integer:= 2;
constant b : integer:= 3;
type state_type is (idle, delay, zero);
signal next_s: state_type;
begin
process (clk)
begin if (rising_edge(clk))then
case next_s is
when idle =>
c <= c + 1;
next_s <= delay;
when delay =>
if (c = a) then
data_out <= '1';
end if;
if (c = b) then
data_out <= '0';
next_s <= zero;
else
c <= c + 1;
end if;
when zero =>
c <= 0;
end case;
end if;
end process;
end behavioral;
another code that i wrote with the same problem
library ieee;
entity ltd_1 is
end ltd_1;
Architecture behavioral of ltd_1 is
constant a : integer:= 1;
constant b : integer:= 2;
begin
process (clk)
begin
if (falling_edge(clk))then
c <= c + 1;
if (c = a) then
data_out <= '1';
elsif (c = b) then
data_out <= '0';
end if;
end if;
end process;
end behavioral;
Thank you in Advance for your help.
You're inferring a register on data_out. You may assign a default value '0' to it, when conditions ( c = a ) and ( c = b ) don't match.
process.. begin if( rising_edge(clk)) then data_out <= '0'; case .... a reset condition it helps too: begin if(clr='1') then data_out <= '0'; elsif(rising_edge(clk)...- Mark as New
one more to mention is, that the FPGA Output Pins are tri-state as long as the FPGA has not configured. Thus in case you do not pull the Signal down by an external resistor, there will always be a high Signal till the FPGA has configured and started to execute programming...- Mark as New
bertulus (http://www.alteraforum.com/forum/member.php?u=77731)
Both didn't work, anyway Thank you so much.- Mark as New
Another point, In the below mentioned code I have a pulse like this [SUB]----0---[/SUB][SUB]----0---[/SUB][SUB]---0----[/SUB][SUP]-----1----[/SUP][SUB]----0---[/SUB][SUB]----0---[/SUB][SUB]---0----[/SUB][SUP]-----1----[/SUP]. The point is that I need only the first "1", I do not need any pulses any more. But as I have to control the pulse width of my signal (When the output is "1") therefore I need to use counter.
I have used the type command and two state (idle and delay). After idle state it goes to delay state and if it was (c=a) output become 1 and if it was (c=b) output become 0 (Because I need to control the pulse width). After it becomes 0 it goes again to delay state. I have tried many other options to don't let goes to idle after delay state. What is your suggestion for rejection of repetition. I mean, only one pulse in output with width controllability?? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity delay_auto is port ( clk : in std_logic; data_out: out std_logic ); end delay_auto; Architecture behavioral of delay_auto is signal c : integer:= 0; constant a : integer:= 5; constant b : integer:= 6; type state_type is (idle, delay); signal next_s: state_type; begin process (clk) begin if (rising_edge(clk))then case next_s is when idle => c <= c + 1; next_s <= delay; when delay => if (c = a) then data_out <= '1'; end if; if (c = b) then data_out <= '0'; next_s <= idle; c <= 0; else c <= c + 1; end if; end case; end if; end process; end behavioral;- Mark as New
You get repeated pulses because you set the state machine back to the IDLE state after the delay state, and hence it loops forever.
Tricky: Thanks for the reply.
I have mentioned this state machine makes a loop. (Idle to delay to idle to delay etc). As I said I want to cancel the loop. Any idea how to cancel the loop for only one output pulse with width controbillity? I tried to describe another state with name of "zaro" to make the counter c <=0 but it won't help. This is what I mean [SUB]----0----[/SUB][SUP]--------1-------[/SUP][SUB]------------------0------------------[/SUB]- Mark as New
remove the return to the idle state from the 2nd state.
--- Quote Start --- remove the return to the idle state from the 2nd state. --- Quote End --- I did before. Please go up and read the thread from the first. When I remove idle from the 2nd state output become 1 before my original code. I attached the image also. Anyway Thank you foe follow up. I really need help for this.
Try this. It has a new state that hangs the state machine:
begin process (clk) begin if (rising_edge(clk))then data_out <= '0'; case next_s is when idle => c <= c + 1; next_s <= delay; when delay => if (c = a) then data_out <= '1'; c <= c + 1; end if; if (c = b) then data_out <= '0'; next_s <= stopped; c <= 0; else c <= c + 1; end if; when stopped =>data_out <= '0'; end case; end if; end process; end behavioral;
I might have not got the clue on your Intention, but in case you just Need one pulse when the FPGA goes online, this should be possible by just implementing a Counter that starts couting with every rising edge of clk as Long as the final value is not reached. the Output can be set high for countervalue being higher than x (this is the number of clocks delaying the high pulse) and being lower than y (with y-x defining the pulse width):
signal Counter : integer range 0 to 1023; signal start_delay : integer range 0 to 1023; signal pulse_width: integer range 0 to 1023; process(clk,POR) begin if (POR='1') then Counter <= 0; Output <= '0'; elsif rising_edge(clk) then if (Counter < 1023) then Counter <= Counter+1; end if; if (Counter < start_delay) then Output <= '0'; elsif (Counter < (start_delay+pulse_width)) then Output <= '1'; else Output <= '0'; end if; end if; end process; The POR signal is a internally generated (or external applied) PowerOnReset signal - not functionally necessary... I just wrote this here - did not check for Syntax in QII yet, thus excuse any typo...
