21594 Discussions
Systemverilog packed structs in Quartus II?
I have a systemverilog header file (types.svh) that contains a number of the following:
typedef struct packed {
bit [127:0] field1;
bit [63:0] field2;
bit [127:0] field3;
bit [63:0] field4;
} name_of_struct;
When I try to synthsize it in a file:
`include "types.svh"
module mod_name(i_port, ...)
input name_of_struct i_port;
Quartus II just dumps out a bunch of errors saying "Verilog HDL error: object "name_of_struct" is not declared. It's like QuartusII isn't actually seeing my `include file or something. Any suggestions? The console window doesn't generate any output as if the `include is actually being evaluated, so I'm not sure what's going on.
this feature may not be supported by Quartus II yet. i don't use System Verilog, can you paste the typedef into your actual source HDL and see if Quartus recognizes it that way?
Hmm. So copying the typedef into my module appears to work:
bit [127:0] field1;
bit [63:0] field2;
bit [127:0] field3;
bit [63:0] field4;
} name_of_struct;
Does Quartus II really not support `including files with common declarations? That seems like such a basic feature.
