21608 Discussions
Tcl script make all pin virtual
Hi all,
Trying follow the instruction base on the Manually Exclude Certain Pins, Such as Clocks. I get some error
http://www.altera.com/support/examples/tcl/all_virtual_pins.html?gsa_pos=1&wt.oss_r=1&wt.oss=quartus%20ii%20tcl%20example:%20make%20all%20pins%20virtual
However, when i type
source Tcl_script1.tcl
make_all_pins_virtual -exclude { inclk0 }
in the tcl consule, it return back
can't read "argv": no such variable
Can anyone help me with this? I attached the achieve file.
Thanks a lot in advance
--- Quote Start ---
Hi all,
--- Quote End ---
I found a solution for your problem. First of all there where some bugs in the script itself.
Also important is that you have to run the script in a cmd-window. You could not pass argument to the script in the tcl-window ( at least as far as I know). have a look to my changes. Don't forget to change the file extension.
Kind regards
GPK
--- Quote End ---
Thanks, i also found the pb. Thanks for the advice as well
