21618 Discussions
Teraisc DE0-CV (Cyclone V) programming error
I am using the DE0_CV_PS2_DEMO project from Terasic. I try to program the device and I get:
Info (209060): Started Programmer operation at Sat Oct 07 07:59:38 2017
Error (209015): Can't configure device. Expected JTAG ID code 0x02B050DD for device 1, but found JTAG ID code 0x020F20DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Sat Oct 07 07:59:38 2017
Info (209060): Started Programmer operation at Sat Oct 07 08:08:05 2017
Info (209061): Ended Programmer operation at Sat Oct 07 08:08:05 2017
Info (209060): Started Programmer operation at Sat Oct 07 08:10:11 2017
Info (209061): Ended Programmer operation at Sat Oct 07 08:10:11 2017
Does anyone know how I can fix this?
Y-
In the Programmer, do an Auto Detect and, if asked, select the correct target device. Also make sure that the programming file you are using is in the correct row in the programmer for the correct device.
