21615 Discussions
The modular SGDMA dispatcher module device driver files
Hii
im using MSGDMA core to transfert data between FPGA and HPS-DDR3 on DE1-SOC board , i create my system using the Qsys but it still need the software which will activate the MSGDMA to start transfert. i read in this document "modular sgdma dispatcher core (https://forum.shelek.ru/index.php?action=dlattach;attach=7257)"about device driver files.
the documment tells that The modular SGDMA dispatcher module provides the following device driver files
where i will found this drivers ?
Refer the following link,
https://github.com/johan92/altera_opencl_sandbox/tree/master/vector_add/bin_vector_add/iface/ip/sgdma_dispatcher
https://www.altera.com/ja_jp/pdfs/literature/hb/nios2/qts_qii55003.pdf
It is probably useful as you might be looking.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Hi
im searching for how to develop a software programing for MSGDMA core, means a soft wich précise the descriptors choosen for my transfer
Hello
I'm also looking for the right header file for a Nios program to test my QSYS system. Simply writing# include modular_sgdma_dispatcher.h causes an error.
I expected the automatic BSP generation in NIOS Eclipse to include the driver and source files that I need to write a program.
Apparently the mSGDMA was correctly identified in the BSP Editor, but somehow it doesn't recognize any driver.
Can someone explain?
https://imgur.com/mtbgvuf
