# - Time Delay
So i understand the# is used as a delay, however
-What clock does it use as reference to delay?
-Is this only for simulation? Does it have no effect on an actual FPGA?
It is only for simulation indeed.
No effect on real design.
Use it in a procedural block of a testbench. It will delay one instruction from the subsequent. As a consequence there's no 'reference' clock. The delay is from one instrction to the following.
If you put
`timescale 1 ns / 100 psat the start of your test bench file, the period defined by the# delay is then in nanoseconds. i.e.# 100 is 100ns.
