20729 Discussions
Timing Contraint on latch
Anyone knows how to constraint the latch related circuitry? I attached a pdf that show the diagram. The clock is running at 10MHz and the timing requirements from input to output is 80nSec.
What is the purpose of this latch? Generally, using latches is not good design practice.
--- Quote Start ---
--- Quote End ---
I know using latch is not good design and do not want to use. Unfortunately, I must use it for my application. I need to find out how I can constraint these latch. I was thinking of using set_max_delay, but I'm not sure whether this would do it since set_max_delay is used for combinatorial logic path.
--- Quote Start ---
--- Quote End ---
Kattice,
Yes, Latch IS a small combinational loop by itself.
just interesting, why you cannot use the flip-flop with Synchronous Clear, because, anyway, you latch by implication depends on the Clock - it clears after 5 clock cycles.
And for me it is looks strange to provide constraints for one specific module; what if you design contains 1000 logic gates, you cannot constraint each.
