Hi All,
Quartus has stopped generating an automatically generated timing constraint file after Quartus 14.0 and I am having problems in constraining the 1000Mbps Small Mac. The design is fully constrained but there are a lot of irregularities relating to the RX Clock of the Mac. If anyone has an example .sdc file to share it would be a great help or just guide me through constraining the Mac. Thanks in advanceLink Copied
The timing constraints will be very dependent on what type of external Ethernet interface you are using - i.e gmii/sgmii/rgmii/transceiver etc.
--- Quote Start --- The timing constraints will be very dependent on what type of external Ethernet interface you are using - i.e gmii/sgmii/rgmii/transceiver etc. --- Quote End --- Yes that much I understand and the interface I'm using for my external Ethernet is rgmii.
--- Quote Start --- Yes that much I understand and the interface I'm using for my external Ethernet is rgmii. --- Quote End --- You might have a look at this example from Altera. http://www.altera.com/support/examples/interfaces-peripherals/exm-tse-rgmii-phy.html However, as I recall the Ethernet independent examples in Time Quest User's Guide follow on for source synchronous timing are a good place to start. http://www.alterawiki.com/wiki/source_synchronous_analysis_with_timequest
Topic Options
