21588 Discussions
Timing report : Generate a report "Clock to output Times"
THAUS1
Is it possible to generate a report Clock to output Times "by hand" using report_timing or report_path SDC commands?
I guess that report_timing doesn't manage timing of the FF into IOPAD...
Thanks for your help.
KhaiChein_Y_Intel
You may generate the Clock to Output Times by clicking on Timing Analyzer: Reports > Datasheet > Report Datasheet
THAUS1
Thanks for your reply, so , how can I check the timing calculated for the "clock to ouput times". I would like to check the datapath & clockpath.
Thanks!
KhaiChein_Y_Intel
You may use report_timing to check the datapath and clockpath
Example of the report:
KhaiChein_Y_Intel
May I know if you have any questions?
KhaiY
THAUS1
Hello, Yes thanks you for your answers, you can close this topic. Have a good day !
