21615 Discussions
Toggle a Pin in always@() ?
Does the following verilog correctly pulse a reset pin?
input [15:0]shadow;
input tach;
input carry_in;
output [15:0]active;
output reset;
reg [15:0]active;
reg reset;
always@(negedge tach)
begin
active = shadow;
reset = 1;
reset = 0;
end
Please help?
Additonally, Is there an overall better way to do this?
Basically I am trying to count the total time a input square wave is high. So when it goes high, I start my counter. The above module does not show the counter, just the output transition module. As it transitions back to low, I want to 1.) copy the count from the counter 'shadow' to another register 'active' 2.) clear the counter to 0
Any advice?
--- Quote Start ---
--- Quote End ---
According to Verilog rules, it doesn't pulse anything, just performs reset=0.
To control a counter and store it's value on a particular event, you better design a synchronous state machine operating with the counted clock.
ok, yes, thinking it over... this is what i need thanks!
fyi; did what you recommended and it works great.
