21615 Discussions
Transceiver arbitrary data rate
zx71769
Hello ,
env: Quartus 18.1   Board: Arriav V 5AGXFA5H4F35C5
I try to input parallel data and output serial data. So I choose Native PHY IP for my design.
Because I want to let it operate lots of data rate 1Gbps~6Gbps (100 Mbps/step)
So I have a idea below:
"PLL IP"  -> "TX PLL IP" -> "Native PHY IP"
I can change PLL output clock by adjusting M/N/C parameter.
TX PLL IP as I know it has fixed magnification.
Native PHY can use external TX PLL.
So if I want to let Native PHY operate 1000Mbps.
PLL IP can output 100M Hz clock. And I can use 10x TX PLL.
So TX PLL can produce 1000M bps. And finally  Native PHY can output 1000M bps data rate.
I am not sure if my thinking is right or not.
Thanks for help !!
SengKok_L_Intel
Yes, you may refer to chapter 17, transceiver reconfiguration controller for more information.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/xcvr_user_guide.pdf
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
