Programmable Devices
21615 Discussions
Tristate Buffer and Open Drain
Hi
I would like to implement open drain function with the verilog code below:
assign q = sel ? 1'bz : 1'b0; //open drain
assign q = sel ? 1'b1 : 1'bz; // use tristate buffer to model open drain function with weak pull up resistor
Both using Pin Assignment with weak pull up resistor on q.
So, are they equivalent? Will the tristate buffer cause the contention?
They are not equivalent. The first one is the right code, if I understood what you mean.
The second one doesn't make sense: you'd always get a high level on that pin, unless you have an external pull DOWN instead of the internal pull up.
You are right. i do a mistake there. thanks
