21615 Discussions
Trouble Installing Stratix 10 Device in Quartus Prime Pro 18.1
DZuck1
I have been trying to install the Stratix 10 Device into Quartus Prime Pro v18.1 and keep running into the same issue (error message attached). I am using the following files downloaded from the quartus website:
  • stratix10-18.1.0.222.qdz
  • QuartusProSetup-18.1.2.277-windows.exe
  • QuartusProSetup-18.1.0.222-windows.exe
I ran both the Quartus Installer and the Device Installer as administrator. Both installers display the same error message when trying to install the Stratix 10. I have successfully installed the Aria 10 into Quartus Prime Pro. Re-downloading the Stratix 10 QDZ file did not help the problem.
AnandRaj_S_Intel
I was able to install stratix10-18.1.0.222.exe for Quartus 18.1 pro in windows 10 environment.
Try by reinstalling quartus and device.
Anand
DZuck1
I will try that. Is it possible there is a conflict with the fact I also have Quartus Prime Standard 17.0.0.595 and 18.1.0.625 installed?
AnandRaj_S_Intel
No , I have quartus version 17.0,17.1,18.0 & 18.1 with sdt and pro edition installed. i have not faced any issues.
Let me know if reinstalling has helped resolve the issue or if you need any further assistance.
Anand
DZuck1
I tried re-installing it and I got the same Stratix 10 device error message. I also got this error message.
DZuck1
DZuck1
From the installer log file:
Executing C:\intelFPGA_pro\18.1/quartus/bin64/unzip.exe -q -o "C:\Users\ \Downloads/stratix10-18.1.0.222.qdz"
Script exit code: 9
Script output:
Script stderr:
 [C:/Users/ /Downloads/stratix10-18.1.0.222.qdz]
 End-of-central-directory signature not found. Either this file is not
 a zipfile, or it constitutes one disk of a multi-part archive. In the
 latter case the central directory and zipfile comment will be found on
 the last disk(s) of this archive.
unzip: cannot find zipfile directory in C:/Users/ /Downloads/stratix10-18.1.0.222.qdz,
    and cannot find C:/Users/ /Downloads/stratix10-18.1.0.222.qdz.zip, period.
[16:26:30] Use native unzip function
Error while reading ZIP file C:/Users/ /Downloads/stratix10-18.1.0.222.qdz
This component will not be installed. Please try download the file again and reinstall it.
Unpacking files
Unpacking files
Executing C:\intelFPGA_pro\18.1/vcredist2015_x64.exe /q /norestart
Script exit code: 1638
AnandRaj_S_Intel
Hi DZuck1,
Let me check and come back to you.
DZuck1
It turns out that my corporate IT was stopping all downloads at 10 GB. I downloaded it at home and got the full 15 GB file. It now installs without issue.
