Programmable Devices
21615 Discussions
Truncation Error
When ever I switch my NIOSII uCOSII project from being stored in onchip_memory to ext_flash I get the following error:
In function 'alt_irq_handler':
/cygdrive/c/altera/90/nios2eds/components/altera_hal/HAL/src/alt_irq_handler.c:98: relocation truncated to fit: R_NIOS2_CALL26 OSIntEnter
/cygdrive/c/altera/90/nios2eds/components/altera_hal/HAL/src/alt_irq_handler.c:98: relocation truncated to fit: R_NIOS2_CALL26 OSIntExit
I've stored larger projects than this in ext_flash before, any idea what this is?
Hi, ThePhil,
Just wondering whether you have this issue fixed and
find out the source of error.
I encounter similar problem in my project and would like
to learn from your experience.
Kevin
I got the similar problem when using Quartus II 9.1 and
I fixed it by changing the setting of Nios II processor in SOPC Builder.
As shown in attached picture, the memory segment for "Reset Vector" should be the same as that in the property of system library "Program memory (.text)".
Also, I found that memory segment for "Exception Vector" would be put together within segment for .text from the linker script that is automatically generated by Nios II tools. Therefore, I think this memory should be set as the same as "Reset Vector".
You can see this linker script from path:
\software\XXX_syslib\Debug\system_description\generated.x
I got the same problem but I use bsp instead of a system library
Well, alt_irq_disable_all() works. But If I change that line of code to alt_irq_disable(TIMER_INTERRUPT) it doesnt work anymore.
