21611 Discussions
U-Boot on Nios II Development Kit, Cyclone II Ed.
This is for if you've got the Nios II Development Kit, Cyclone II Edition and you want to use U-Boot on it. I've attached a patch that adds support for that kit's "standard" example design. The patch is for U-Boot 1.1.4.
To use:
cd ???/u-boot-1.1.4 patch -p1 < ???/u-boot-1.1.4-n2dkc2.patch make EP2C35_config make all
The configuration puts the console on the JTAG UART.
The patch also includes support for several other Altera boards from a custom U-Boot 1.1.3 version by Psyent.
Note: the patch also changes the tool names used from nios2-elf-* to nios2-linux-uclibc-*, so change it back if you&#39;re on Cygwin.
Just to be clear on small, but important point:
The sources at psyent.com are not custom at all ... they are taken directly from
the u-boot souce tree and contain all Nios-related patches that have been submitted
to the u-boot project. Any changes are simply the elimination of warnings or
build errors for the typical development environment (cygwin). Unfortunately, the
u-boot project is _very_ busy and patches can now take as long as several months
to be applied. All of the boards supported by the code at psyent are part of pending
u-boot patches.
Hopefully, this long delay between submitting patches and their application to
the main source tree should improve now that u-boot is using git. I&#39;m currently
evaluating the feasibility of setting up a git repository for nios development -- to
make the latest nios patches available immediately and still maintain sync with
the latest platform independent code.
The normal way to do this with u-boot is to simply set CROSS_COMPILE with the
make command:
$ make CROSS_COMPILE=nios2-linux-uclibc-
--Scott
