21607 Discussions
UART RECEIVE interrupt in nios int status = 0; status = IORD_ALTERA_AVALON_UART_STAT
I need to read the uart data on interrupt bases ,means whenever there is something on rx pin of uart interrupt should get generated and in ISR should read it.
I have tried by using bellow code but didn't get any success ...
char data;
volatile int edge_capture;
void uart_isr()
int status = 0; status = IORD_ALTERA_AVALON_UART_STATUS(UART_0_BASE);
if(status & 0x80)
data = IORD_ALTERA_AVALON_UART_RXDATA(UART_0_BASE);
interrupt_count = interrupt_count +1;
void uart()
void* edge_capture_ptr = (void*) &edge_capture;
alt_ic_isr_register(UART_0_IRQ_INTERRUPT_CONTROLLER_ID,
UART_0_IRQ, uartR, edge_capture_ptr, 0x0);
alt_ic_irq_enable(UART_0_IRQ_INTERRUPT_CONTROLLER_ID,UART_0_IRQ);
IOWR_ALTERA_AVALON_UART_CONTROL(UART_0_BASE,ALTERA_AVALON_UART_CONTROL_RRDY_MSK);
sometime ISR just gets called once and sometime it will be keep getting even if there is nothing on uart RX bus..
M i doing something wrong here ..plz suggest me.
If anyone has example code for uart interrupt receive plz share .
Thanks and Regards
Ankur
