21602 Discussions
USB Blaster 2 + MAX10 - TCK / programming issue
I've designed a MAX10 10M02SCE144I7G board to be programmed with JTAG. Programming device is Altera USB Blaster II. When I try programming with Quartus Prime, it says:
Error (209040): Can't access JTAG chain
Error (209012): Operation failed
TCK is pulled down with 10k,
TMS and TDI are pulled up with 10k
I've checked TCK signal with an oszilloscope, showing a broken signal, see attached pictures.
To verify, I've tryed connecting directly onto USB blaser: GND and +3V3 (VCC TARGET) pins (1,10 & 4) + TCK pin pulled down with 1kOhm (so no connection to my board), the TCK clock still shows the same weird behaviour.
A 2nd. USB Blaster is showing the same pattern.
Can somebody please help me identifying the problem?
Attachment: TCK signal when pressing "Start" in the Quartus Prime Programmer, zoomed in and complete view.
the USB-Blaster II download cable has a default TCK frequency of 24 MHz. Can you try to decrease TCK frequency to 6MHz? For more information one can check the following specification, https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
Martin
The JTAG signals need to be clean before the Quartus programmer works properly. The EE's I work with say it is important to treat them as a transmission line. See the JTAG spec for details on termination requirements.
I've lowered the clockrate to 6MHz and added some termination, it's working now!
Thanks for your help guys, really appreciate it!
