21611 Discussions
USB Blaster problem
I have a chip USB Blaster Rev C. When I program CPLD EPM7064SLC44-10 with Quartus II sp2 12.0 programmer, the process bar goes to 100% and then it shows "Failed". How can I fix this error ?
However, it works with ByteBlaster(Parallel port programmer).
Thank you.
Do you know whether or not the USB-Blaster actually works?
Rather than programming the MAX CPLD, try verifying its JTAG ID using the Quartus debugger.
Some of the Rev C USB-Blasters came with a flex cable while others come with a ribbon cable ... I recall problems with one of those, but forget which ... I have USB-Blasters with both and they work fine for me.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Have no idea, but I know another guy that has a similar problem. Anyway, I can't test my USB blaster with another device family, because I have only EPM7064.
I'll try to check its JTAG ID...
Thank you, Dave.
*sometimes* when the programmer just says "failed", you get a slightly more interesting error message in the Quartus main window, in the "System" log (the first tab in the messages section)
--- Quote Start ---
--- Quote End ---
If you remove the cover of the USB-Blaster, you can loop its JTAG cable back onto an internal JTAG header (which is also a MAX device), and see if you can read the JTAG IDCODE of that device too.
If you want to check the output drivers are working, you can jumper from the VCC_TARGET pin of the second header internal to the USB-Blaster to that on the USB-Blaster output header, and then probe TCK, TMS, and TDI.
Cheers,
Dave
...Before I didn't see the "System" log. When I tried, Programmer gave my this error: "Error: JTAG ID code specified in JEDEC STAPL Format File does not match any valid JTAG ID codes for device". Then I found some information about this problem on Altera Forum. Some guy said to connect a pull-down resistor to TCK pin.
But it did not fix the error.
I measure the voltage on the pins:
TCK = around 0 volts = constant
TDO = 4 volts = constant
TMS = around 0 volts = constant
and TDI = some signal with amplitude 1v
Also, I opened my USB Blaster and... there is no any CPLD inside. It based on uC 'Silabs' with IC 74LVC125. Maybe because it is the chip USB Blaster. I bought that in Ebay...
Thank you very much,
Yaroslav.
--- Quote Start ---
--- Quote End ---
I'd recommend buying a Terasic USB-Blaster for $50. I've not had any problem with them.
Cheers,
Dave
Hi Yaroslav,
I would also try a different USB Cable than the one that is provided with the Altera USB-Blaster.
Depending where you Purchased your USB-BLASTER, sometimes the Stock USB cables are very cheap and are prone to Shorts or an OPEN connection.
Can you post a Picture of how you're interfacing the chip?
It would help to see your interface setup.
Cheers!
-Gerry
Hi Yaroslav,
--- Quote Start ---
--- Quote End ---
What does the outside of your USB-Blaster clone look like?
Since its a SiLabs clone, its likely based on this design here:
http://ixo-jtag.sourceforge.net/archive/ixo_de_usb_jtag.html
and I think this is a photo of its internals:
http://servux.free.fr/tmp/usbblaster.jpg
If you wanted to "debug" your problem, you could look at the ixo.de source code for the clone.
Cheers,
Dave
Finally, I fix my problem ! The solution was to connect USB-Blaster directly to CPLD (through 74HC244), connect VCCtarget and +5Vcpld together and add a pull-up resistor to TDI pin. The both programmers(my USB-Blaster and also Terasic USB-Blaster) are working now.
Yaroslav.
Hi Yaroslav,
--- Quote Start ---
--- Quote End ---
What was wrong with the 74LVC125 on the SiLabs USB-Blaster?
--- Quote Start ---
--- Quote End ---
Your board should have already done that, i.e., the VCC_TARGET pin on the USB-Blaster is supposed to power the buffer inside the USB-Blaster. That is how the USB-Blaster ensures the logic levels transmitted to the board are compatible with the device.
If your board did not connect VCC_TARGET, then that would explain the problem.
Cheers,
Dave
--- Quote Start ---
Hi Yaroslav,
Cheers,
Dave
--- Quote End ---
Nothing ! My CPLD board is designed for ByteBlaster so it has 74HC244 on it to protect the CPLD. I tried to connect USB-Blaster to the same connector, but it did not work.
About VCC_TARGET, I didn't know that's why I didn't connect it...
Thank you,
Yaroslav.
