21611 Discussions
[USB-Blaster2] unable to flash image due to Error (210001)
SeongLim
I have problem to flash .sof image through linux enviroment It will print out error (210001) not valid sof file
Here is my result :
linux os : SUSE Linux Enterprise Server 12 SP5
At same time i did check usb-blaster2 connection so far no issue able to detect in my linux enviroment.
but when switch to window enviroment  I able to flash .sof image with no problem
Here is result :
Apprieciete if can provide me some guidance thanks.
regards,
Seong lim
Fakhrul
Hi SeongLim,
Have you tried with another sof file? let's generate a new sof file and try to load it. Would you mind to share the (not valid) sof file?
Fakhrul
SeongLim
Hi fakhrul,
Yes, I did try different Sof file but unfortunate still get same error.  As per request Sof file attached, please check thanks.
Seong lim
Fakhrul
Hi SeongLim,
I apologize for the delay. I've been attempting to reproduce the issue on my end, but I haven't been able to find the Stratix 10 SG variant. Have you attempted to program it using the Quartus programmer GUI?
Fakhrul
SeongLim
Hi Fakhrul,
The issue has been resolved. It because I am using the Quartus prime programmer standard version which is incompatible for stratix10 family.  Here is the problem I found when I run GUI mode.
Version: QuartusProgrammerSetup-23.1std.0.991-linux
Upon installing Quartus Prime Programmer Pro version, the issue was resolved. Now, it can automatically detect the Stratix 10 device family when I run it in GUI mode.
Result from Linux CMD:
Btw. I appreciate your assistance with this issue thanks.
Seong Lim
Fakhrul
Hi SeongLim,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Fakhrul
