21607 Discussions
USB is not detected
I'm working with SoCrates board, and I'm trying to use USB mouse. Now I have my LED mouse blinking. But lsusb doesn't detect any hardware, except for root hub. This is also happening with my USB drive and with my USB HUB. All of them get power, but non of them actually works (USB is not detected, neither mouse, and HUB even doesn't give any power to devices plugged in it (when i plug mouse LED just blink for a moment). Do I have to include som drivers for this? I have included CONFIG_USB_MASS_STORAGE=y, so it should be able to detect USB flash? Also I've included Synaptics_USB driver, but I have message in dmesgs:Error: Driver 'synaptics_usb' is already registered, aborting...
Does anyone have any idea what should I do? And do I need drivers even for a HUB?
Thank you in advance,
Bojan
P.S. I'm using kernel 3.12
happened for all usb mouse type? as some mouse sending a 8-bit and some in 16-bit reporting format as a usb mouse descriptor
I was using wrong end of cable to plug in mouse :)
Flash and mouse now works fine, but I'm having problems with HUB. Do I need some drivers for HUB?
i think you need a driver to allocation multiple end point.
According to me you need a driver for HUB.
