21594 Discussions
Unable to generate/find .elf file in NIOS ?
I am using Altera Quartus 14.1 Web Edition [Cyclone V]. I need to test the input and output signals of custom board using Quartus.
I need to execute my task using Quartus II +Qsys +Nios Eclipse. I did 100% successful programming process. But in NIOS II, i am unable to find/generate .elf file. I have followed this link for my tutorial https://www.youtube.com/watch?v=vrnssrbix_q. But eventhough i am unable to generate .elf file. Please anyone guide me what`s wrong, and find the attachment.
You are getting an error .elf file will be generated if the build is successful without error.
Try by "Enable Small C library" or enable, "Enable Lightweight Device Driver API" in the BSP settings.
or can you attach the program file?
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
MChin10
I am facing same issue.
How to change the setting of BSP
