I am getting some experience with Altera FPGA's and ran into the following issue. I want to program FPGA configuration data (NIOS II processor) and the program into the EPCS memory on my DEx-board. I want to do this with the NIOS II Flash Programmer. When running this program I got the following error: EPCS signature is 0x16 EPCS identifier is 0xC22017 No EPCS layout data - looking for section [EPCS-C22017] Unable to use EPCS device. When I add the next lines to the "nios2-flash-override.txt"-file I got the error : Syntax error in override file (line 2) when reading the file.
*# EPCS1N (lead-free)
sector_size = 32768
sector_count = 4
*# EPCS4N (lead-free)
sector_size = 65536
sector_count = 8
*# EPCS16N (lead-free)
sector_size = 65536
sector_count = 32
*# EPCS64N (lead-free)
sector_size = 65536
sector_count = 128
Can anybody help me with the newby question? Thank you and best regards, Wamor
For some reason I have mixed up some numbers. After adding the following line everything works ok:
C22017] *# EPCS64N (lead-free)
sector_size = 65536
sector_count = 128
Best regards, Wamor
