21598 Discussions
VGA - horizantal sync pulse generation
hey,
I am trying to generate horizantal sync pulse with FSM.
I write the next verilog code:
module horizantal_sync_pluse ( clock, //system clock reset, //system reset sync_pulse //horizantal sync pulse ); //State machine parameters parameter Scan_Line=1'b0; parameter Gen_Sync_Pulse=1'b1; //---------------------------------- input clock; input reset; output sync_pulse; reg sync_pulse; reg state; reg counter; always@(posedge clock, negedge reset) begin if (reset==0) begin state<=Gen_Sync_Pulse; sync_pulse<=1'b0; end begin case (state) Gen_Sync_Pulse: if (counter==11'h00BC) begin //188 counter<=counter+1'b1; state<=Gen_Sync_Pulse; sync_pulse<=1'b0; end else begin state<=Scan_Line; end Scan_Line: if (counter==11'h639) begin sync_pulse<=1'b1; counter<=counter+1'b1; state<=Scan_Line; end else begin state<=Gen_Sync_Pulse; counter<=0; end default: state<=Gen_Sync_Pulse; endcase end end endmodule
after compilation I get Warning: Latch counter[0] has unsafe behavior
Warning: Ports D and ENA on the latch are fed by the same signal sync_pulse~5
This warning is on each bit of the counter.
why is it? how can I avoid it?
I haven't done verilog for years but I think you got simple error,
if reset == 0
begin
end
else begin // you should put else here
Thanks. it happens to me sometimes, skip on this or that word. very diffecult to find asuch mistake by myself.
Thanks again
Another question.
I would like define
But I don't want that it will be showed in block diagram as parameter to change.
please see atachment.
How can I do it?
Well you can just not declare the unwanted parameters and use their assigned values directly in your code to replace their names.
Parameter is for helping code readability/updating only. At compile time they are replaced by its value.
--- Quote Start ---
I would like define
How can I do it?
--- Quote End ---
Try
localparam Scan_Line=1'b0;
localparam Gen_Sync_Pulse=1'b1;
Cheers,
Dave
Well Dave, I should add you to the list of My Gurus. So far only FvM and josyb managed to get there.
Hey Kaz,
--- Quote Start ---
--- Quote End ---
You are too kind.
I just happened to see localparam used in some of the Altera Verilog :)
Cheers,
Dave
