21602 Discussions
Unexpected H2F-LW AXI Activity
I'm experiencing unexpected behavior on the H2F-LW AXI bus for the Arria 10 SoC SoM Dev-Kit (Achilles).
I basically have a HPS-only example that includes DDR4, H2F-LW AXI port and a PIO-LED (output only) Qsys component connected to the LW port. This setup works as expected and I can toggle the LED(s) from Linux running on the SoC using the "/dev/mem" device interface.
The problem occurs when I add the SPI (3-wire) Qsys component to the H2F-LW AXI bus. In this case, the PIO-LED continues to behaves as expected, but I also observe unexpected activity from the SPI-SCLK signal. After debugging further, I observed write assertions on the Avalon-MM bus in the SPI Qsys component. I attempted several modifications such as changing the base address, but nothing seemed to help. I'm not observing this behavior on the PIO component.
Any ideas? Thanks!
