21615 Discussions
Unexpected Voltage output on pin AB19
Joseph_Wilger
For this pin (AB19) we are seeing partial transition from 1.8 V to 1.3 V.
The good PCBA the upper level is 1.8 volt rail.
On a good PCBA, the lower level is ≤ 0.3 V.
On a bad PCB, the upper level is 1.8 volt rail.
On a good PCBA, the lower level is ≤ 1.3 V.
This level does not allow the remainder of the circuit to detect the lower level transition.
FvM
unfortunately I don't have a crystal Ball, please tell us which board you are talking about? Presume it's a common development board with schematics available.
Farabi
Could you please tell :
1- what device
2- what board
regards,
Farabi
AqidAyman_Intel
Any updates for this issue?
