Programmable Devices
21592 ディスカッション
Unexpected Voltage output on pin AB19
Joseph_Wilger
ビギナー
762件の閲覧回数
For this pin (AB19) we are seeing partial transition from 1.8 V to 1.3 V.
The good PCBA the upper level is 1.8 volt rail.
On a good PCBA, the lower level is ≤ 0.3 V.
On a bad PCB, the upper level is 1.8 volt rail.
On a good PCBA, the lower level is ≤ 1.3 V.
This level does not allow the remainder of the circuit to detect the lower level transition.
ラベル(1)
  • I|O
0 件の賞賛
3 返答(返信)
FvM
名誉コントリビューター II
661件の閲覧回数
unfortunately I don't have a crystal Ball, please tell us which board you are talking about? Presume it's a common development board with schematics available.
Farabi
従業員
386件の閲覧回数
Could you please tell :
1- what device
2- what board
regards,
Farabi
AqidAyman_Intel
従業員
95件の閲覧回数
Any updates for this issue?
返信
