21615 Discussions
Updating EPCQ data over Ethernet
Hello folks !
I want to run a simple code that allow me to update the existing NIOS II application (stored on epcq flash) with a new application image over Ethernet.
I would like to use RPD file. NIOS II will handle the incoming rpd file from ethernet, and write it to the epcq flash,
Any Ideas ????:confused::confused::confused::confused:
Look for AN429 in https://www.altera.com/products/processors/support.html
It is rather old though.
Thanks Rodo for your reply.
I already went through AN429, and its not straightforward. I am looking for C code with three functions:
1- Read a file from Ethernet.
2- Write this file to EPCQ flash.
3- Verify the programmed data on flash
