In Cyclone-III EP3C16, there are 4 PLLs. I only need to use 2 of them. Each PLL has one dedicated physical output pin. In my application, I need 2 or 3 physical outputs from one PLL. I think that I could use the output pins of those 2 unused PLLs and connect 1 or 2 outputs of the used PLL output to them through GCLKs then to outside of the FPGA. Would it be possible for somebody to confirm this? Many thanks.
There is only one dedicated output pin that is directly driven by the PLL. A PLL can drive other I/O, but most drive a global to get to these I/O. The global adds a little jitter/noise to the clock output.
That being said, I've never seen using regular I/O as a problem. I've seen people drive clocks off regular I/O and run 200-300MHz interfaces quite easily. What are you doing with your clocks? Personally, I think using regular I/O is almost always good enough(I've never seen a case where it wasn't) and that the dedicated outptus tend to just throw users off thinking they have to use it.- Mark as New
I agree with Rysc. Regarding your question, usually what I do when I have a question like yours is just perform a simple test compilation in Quartus. Make a simple dummy project and drive the clock outputs to the four output pins of your choosing. Quartus will tell you if you've done something wrong.
Most likely you'll get a warning regarding jitter performance on any clocks that use a global route rather than a dedicated clock output path. And going by Rysc's experience (which I would trust above my own) you could ignore this. Jake- Mark as New
If you drive the the clock out using a DDROUT primitive, the jitter warning will disappear.
