21615 Discussions
Use PLL CLKOUT pins as regular I/O pins in Stratix 10
Wujun
Can I use PLL_2C_CLKOUT0n and PLL_2C_CLKOUT0p,PLL_2C_CLKOUT0,PLL_2C_FB0 as regular I/O pins in Stratix 10?
Refer to the Pin list of 1sg280es UF50, they are IO function, and PLL CLKOUT are optional function. So I think they can treat as regular I/O pins?
Rahul_S_Intel1
Please note the above pins can be used as I/O or dedicated clock signals . Please refer the page no: 5 of the pin connection guidelines.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/stratix-10/pcg-01020.pdf
RS
Wujun
Thank you for your explanation.
Page no 5 has a description about PLL_2C_CLKOUT0,PLL_2C_FB0, and it can be treated as I/O. Page no 6 has a description about PLL_2C_CLKOUT0n, but it says "can be used as two single-ended clock output pins or one differential clock output pair." Does PLL_2C_CLKOUT0n cannot be treated as a single-ended input pins?
Rahul_S_Intel1
Hi Wujun,
Apology for the confusions, the sentence only meant that the pin have the capability to use as an single ended and as differential ended signals. That means to say PLL_2C_CLKOUT0 pin pair ( p and n) can be used as differential pair signals. and Individually can be used as single ended signals.
PLL_2C_CLKOUT0p one signal
PLL_2C_CLKOUT0n another signal
Hope it clarifies.
Rs
Wujun
Hi RSree
Thank you. I made a typo, and actually I wanted to ask “Does PLL_2C_CLKOUT0n cannot be treated as a single-ended input pins?” Anyway, these two pins can be treated as two single ended I/O signals.
