21602 Discussions
Using JTAG on MAX10: SHIFT_IR reads 0x151 instead of 0x155. What does it mean?
MSchu50
We are using the JTAG interface on MAX10 and in general this works as expected.
https://www.intel.com/content/www/us/en/programmable/documentation/sss1396244916395.html#sss1396246786298 states that the content of the Instruction Register is a 1010101010 pattern (0x155), and we should check it. Usually this is true.
Sometimes we get 1000101010 (0x151) as previous IR content, just one bit flipped. It is always the same one, and it is visible on the line.
The issue seems to be bound to hardware. Some HW shows it repeatedly, some never.
If we ignore this bit, everything still works as expected. So contrary to what the linked document states, the device seems to have well reached the proper state.
So I would like to ask: What is the meaning of this bit? Does the MAX10 try to tell us something we should care about?
YuanLi_S_Intel
Hi Markus,
Sorry for being late, as i was checking with the team about this. Regarding to the diff pattern that you saw, as long as it starts with "10..", it shouldnt be any problem on it.
Thank You.
YuanLi_S_Intel
Hi Markus,
Thank You.
MSchu50
Hi YL, thank you for checking with the team and your response! Regards Markus
