I am using ghrd.v to setting project gpio for a while. It work correct before, but someday I found I couldn't replace gpio. For example, I tried to replace a pin from gpio[2] to gpio[19], compile is fine, but it still maintain gpio[2] actually. I use quartus 21.1 lite and my board is DE0 board with cyclone V 5CSEMA4U23C6N. How do I fix the problem?
syuanyou
Can you show your code? Did you make the change in the Pin Planner? More details needed.
Hi syuanyou,
Do you still need help on this?
May I know did you check with any other GPIO pins which having signals which you can observe?
Aik Eu
The problem still exist. The other GPIO pins have the same problem. I replaced the GPIO in the pin planner with a new variable and reconnected, but it didn't improve the issue. I also tested it using SignalTap, and the GPIO operation on SignalTap is working correctly, just like the settings in GHRD.
Thank you
Hi syuanyou,
I think can try with any GPIO LED indicators which you can use to observe the signal as reference to the issue on your design which you are facing:
For your reference:
Aik Eu
I found the issue. the path to the .sof file in the programmer was incorrectly set to the previous file. After correcting it, everything is working fine now.
Thank you.
Hi syuanyou,
Glad to hear that the issue has been resolved. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
