21615 Discussions
Using internal oscillator EPM240
tyassin
I would like to use the internal oscillator in EPM240. I understand that it is not precise, but nevertheless it is OK as I then can spare an external oscillator.
With the MegaWizard plug-in manager in Quartus the oscillator files are generated, which I have attached. I am seeking information how to include these in a design? Is it also possible to do it without the schematic editor, I would like to do it all in VHDL.
Thank you.
sstrell
Just like any other IP, use the instantiation template and component declaration to instantiate the IP in your design.  Edit the instantiation to make connections to the rest of your design.  Then add the .qip file to your project files (Project menu -> Add/Remove files) or just put the files in your project directory and they will be added to the project automatically..
sstrell
AqidAyman_Intel
Thank you for the answer provided.
I wish to follow up, is there any more clarification needed on this question?
tyassin
Thank you for the answer and quick response time.
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
