I try since a couple of days to get cs, read and write signal on outputs of my de0 nano board. The goal is to drive a motor controller (LM628) which needs ck 8Mhz, cd, rd ,wr and a 8 bits data bus For the ck it's ok. I use a altpll function under Quartus. For the other signal I have created under Qsys: Clock source (50Mhz) Nios2/e processor Generic Tristate controller Tristate Conduit Bridge I take care of the links between each block. They have all the same clock. No error message during generation. Under Eclipse I write a small loop which make a write then a read on GENERIC_TRISTATE_CONTROLLER_0_BASE Then I run the program ... but nothing on outputs! cs stay at 3V3. Someone has an idea on this problem? I see a note (2011) that we have to put a Tristate conduit Pin sharer on some kind of Cyclone. I tried but no change. Thank you per advance for your help SergeLink Copied
