Programmable Devices
21615 Discussions
VCXO , Transceivers & Refclk
can i input LVDS refclk to the transceivers block? i need it for HD-SDI .
do i need to terminate something because of that?
does anyone has a reference design for using VCXO for syncing the SDI-HD video clock?
THNX!!
Download the Stratix IV GX AV kit and install it.
In there you should find the schematic for the board and all your needs shall be met.
You should be able to reduce the circuit down as the board may have more flexibility then you need for your design.
